Author | Topic: Engine lite |
Grt guy657 Prowler Enthusiast From:cottonwood ,Al. USA |
posted 06-26-2017 07:22 AM
Engine lite came on |
Bob Mears POA Site Supporter Prowler Junkie From:Lubbock, Texas, USA |
posted 06-26-2017 08:30 AM
Funny you say that. My engine light has been on for a couple of years. Actually it came on right after I purchased it. Figured po had just got it off to sell it. Had the local Dodge store look at it and they couldn't fix it. So I've just been living with it. I haven't driven the Prowler in about a year till this past weekend. I noticed the engine light wasn't on! Healing power of the Prowler I guess.... |
posted 06-26-2017 08:31 AM
If the car is still running OK, go to AutoZone and have them readout the code. If you just got gas, make sure the gas cap is on tight. Let us know what code you come up with and more help is available. |
posted 06-26-2017 09:12 AM
First thing to try is simply disconnect the negative cable to your battery and let it stay that way for about a minute. Then reconnect the battery cable and then see if the light has gone off. Disconnecting the battery for about a minute allows the "computer" to re-set itself. Checking the gas cap as Steve suggested is also a good idea as a loose cap will cause the "check engine" light to come on. If neither of those cures it, take Steve's advise and go to AutoZone and ask them to use their analyzer to print you a readout which should diagnose your problem. It just takes a few minutes and they do not charge for the service.
You can buy the analyzer and do it yourself but they won't do it for you....BTW...The analyzers are not very expensive. Good luck...
This message has been edited by bjprowler on 06-26-2017 at 09:24 AM |
BillyC POA Site Supporter Prowler Junkie From:Galveston, Texas USA |
posted 06-26-2017 09:23 AM
If disconnecting battery does not clear it, go to amazon and get a code reader, google the code, to find the problem, and clear it. www.amazon.com/Oxgord-Scanner-Engine-Diagnostics-Direct/dp/B011Q18D14/ref=sr_1_cc_2?s=aps&ie=UTF8&qid=1498486859&vehicle=2000-43-263-20--8-1-7-4270-210-1-1-627--1-0&sr=1-2-catcorr& ymm=2000%3Aplymouth%3Aprowler&keywords=code+reader |
posted 06-26-2017 03:22 PM
as others have suggested , Check and make sure your gas cap is screwed on tight. If it's not, then tightened it and disconnect, wait 15 and reconnect the battery again. This message has been edited by BeWare on 06-26-2017 at 03:23 PM |
posted 06-26-2017 04:04 PM
Gas cap fixed it> |
dru POA Site Supporter Prowler Junkie From:Texas |
posted 06-26-2017 09:36 PM
quote: Almost sounds like a thank you is in order?? |
TucsonJer POA Site Supporter Prowler Junkie From:Tucson, AZ, USA |
posted 06-26-2017 10:47 PM
Thank You Dru, I agree... |
Gravy Prowler Newbie From:Clarkston, MI 48348 |
posted 07-02-2017 12:40 PM
My engine light came on today. After reading the posting I tightened my gas cap and disconnected the negative cable for a few minutes and the light went out. Thanks for the help. |
posted 07-03-2017 10:33 PM
Thank you all for the help. |
JOYRIDE POA Site Supporter Prowler Junkie From:Moncton N.B. Canada |
posted 07-04-2017 07:15 AM
One big Happy family |
posted 07-09-2017 09:01 AM
Have had my check engine light come on several times since 2008. Just did the disconnect negative battery cable, everything was fine afterwards. Do run your Kat for at least a hundred miles before going through state inspection, however. |
