Author | Topic: REAR BRAKE ROTORS AVAILABLE |
posted 06-20-2017 01:31 PM
If You are looking for REAR ROTORS for your Prowler, You can switch over to cast iron rotors. These Rotors are available from any NAPA AUTO PARTS location. By using cast iron you will add a few pounds to your car, but you will be able to use ceramic pads. THE NAPA PART NUMBER IS NB 4885993 If anyone has a problem ordering them, I can get them for $ 38.50 each You can also take them to some auto parts stores in your area that have a machine shop to have them drilled & slotted for a nicer look This message has been edited by phil2237 on 06-20-2017 at 02:46 PM |
posted 06-20-2017 01:46 PM
posted 06-20-2017 06:29 PM
Thanks Phil Good Info. |
posted 06-21-2017 08:22 AM
You will most likely be able to go to ANY auto parts store & give them the NAPA number to cross over to a different brand as this Rotor is made by many manufactures. Do not use any other number to cross as the other number posted is a larger rotor. So if you don't have a Napa dealer in your area , don't panic |
posted 06-29-2017 05:31 PM
Just for future reference, the following post has additional information related to these rotors. http://www.prowleronline.com/ubb/Forum2/HTML/005536.html |
posted 06-29-2017 06:31 PM
Excellent! Thank you for your hard work!
quote: |
posted 06-29-2017 06:41 PM
Thanks, Phil! |
posted 06-29-2017 10:03 PM
Thanks Andria and Phil. Great work. |
posted 06-30-2017 12:38 PM
Great example of "Never hurts to ask" and even a better example of what POA and its members... Andria... Thank you so very much for sharing your info and for all the hard work and research!!! Phil... Thanks for all the efforts and for confirmation!!! I am the proud owner of 3 pairs (Ceramic pads have been ordered).... Just awesome!!!! |
Professor Prowler Prowler Newbie From:Cedar Hills, Utah, United States |
posted 10-11-2020 04:02 PM
I ordered 2 rotors from Napa with that part number for my recently purchased Prowler, and FYI they did not fit, not even close. They were too small, even the lug spacing was too small. Does anyone have an update, perhaps the part number has changed? Thank you in advance. |
jwallis POA Site Supporter Prowler Junkie From:JOHNSONBURG, PA., USA. |
posted 10-13-2020 05:32 PM
There’s a set for sale in the classified section here . The original ones were discontinued and no longer available. |
posted 10-15-2020 12:36 PM
These will not work. don't order???? Maybe Tony can remove this misinformation. |
posted 10-15-2020 02:22 PM
the rotors are listed for a '89 le baron, I looked up bolt pattern for the '89 le baron , it is 5x100, the bolt pattern for a prowler is 5x114.3
This message has been edited by mslc10 on 10-15-2020 at 02:35 PM |
posted 10-18-2020 10:54 AM
I am happy to help, thank you for your kind words! |
