General Prowler Discussion That noisy, rattly, serpentine belt. Any cures?
Author | Topic: That noisy, rattly, serpentine belt. Any cures? |
1st Prowler Ever POA Site Supporter Prowler Junkie From:Alliance, Ohio, USA |
posted 04-26-2017 01:14 AM
Has anyone came up with a solution for the vibrating serpentine belt on the 99's? Has there been a second idler bracket and pulley made for these? Rob, 99 purple/red. |
posted 04-26-2017 06:34 AM
The alternator with a one way clutch used on the 2000 and later cars helps. |
posted 04-26-2017 08:44 AM
The Idler bracket and pulley are the same as used on the Chrysler 300m - and other Chrysler 3.5 motors .. as for the Alternator clutch that might be where the noise is coming from ??? I had that problem and the Clutch replace was the fix ... |
posted 04-26-2017 10:13 AM
FYI, which may or may not be useful - From an old post:
posted 04-26-2017 01:38 PM
Mine has the regular solid pulley on the alternator. Not familiar with the clutch style, saw pics of it, maybe more to go wrong? |
posted 04-26-2017 02:23 PM
Chrysler solved this problem by replace standard alternator with decoupling unit. Black snoot on front of pulley is decoupled/override mechanism. Direct bolt on replacement. No modifications needed. Used on many Chrysler 3.5L engines. Pick alternator up at a junk yard if need be. Also, be sure to re-check belt for correct tension. Critical. |
