Author | Topic: springs ? |
posted 04-06-2017 08:25 PM
Does any one know if the Dynamis springs will fit on Koni Shocks ?? and if there is a tool to remove the springs ??? |
posted 04-07-2017 12:56 PM
Jim .. you sure ask some difficult questions. I would say just a normal spring removal compression tool will work on any shock. Then install Dynamis springs on the koni shock. Look to make sure it seats well in the botton and top.
This message has been edited by robin on 04-07-2017 at 12:57 PM |
posted 04-07-2017 02:04 PM
Thanks Robin Good Info ... |
posted 04-07-2017 02:15 PM
The Prowler Springs will interchange between Dynamic Suspension and Koni Shocks.. |
posted 04-07-2017 07:02 PM
Thanks Buddy that is good to know .. Now if I can get them off with out killing my self will be the trick .. I had a set of coil spring compressor tool on it today tight them up and they started to bend the 3/4 inch rods while it was compressing the spring so I will need to find some thing better to work with .. I should just leave be but might try something different one more time .. Thanks jim ... |
posted 04-07-2017 08:09 PM
When you find what works , please post it Jim. I will be doing the rear springs soon. |
posted 04-07-2017 08:19 PM
Spring compressor at Amazon. http://www.amazon.com/OEMTOOLS-25550-MacPherson-Spring-Compressor/dp/B000CMDPLM |
posted 04-08-2017 06:51 AM
padroo Thanks -- I think That set might be better than the set I have the outer lip is not as long and might slip by the shock easier when compressed .It is one strong spring to be so small .... Jim |
posted 04-08-2017 03:13 PM
Just a confidence builder for Mark when he does his rear shocks. A good helper is needed. remove spring...just take to a garage they can remove it for you ..No need for you buy a spring compressor unless you are going into business. clamp the shock in a good vise..... Get a good size monkey wrench.
Then slip a good leverage bar over the end....
once you break it free it will come off easy..... This message has been edited by robin on 04-08-2017 at 06:10 PM |
posted 04-08-2017 03:18 PM
quote: Jim, you're better off having a Machine Shop swap everything over for you as they have the correct equipment for the job as well as the expertise. |
posted 04-08-2017 08:09 PM
I had to use a 36" monkey wrench to break the Dynamics loose. |
posted 04-09-2017 10:30 AM
IF anyone has a spare set of the "Forks" that screw onto the bottom of the rear shocks, I am looking for a pair to have on hand for someday. |
