Author | Topic: Side Mirrors On Prowler |
dean1948 POA Site Supporter Prowler Junkie From:Gastonia,N.C. USA |
posted 03-17-2017 05:28 PM
Has anyone ever replaced their Mirror Glass on their Prowler?. If so, how is the best way to remove the bad one? I would like to replace mirror and back plate.... |
posted 03-17-2017 08:00 PM
I have not had any problem yet but here are a few links to look through and maybe you can find an answer. http://www.google.com/search?rlz=1C1CHFX_enUS573US573&espv=2&q=mirror+glass+site%3Aprowleronline.com&oq=mirror+glass+site%3Aprowleronline.com&gs_l=serp.3...22505.22505.0.23331.1.1. 0.0.0.0.105.105.0j1.1.0....0...1c.1.64.serp..0.0.0.WVjqj9424y0 |
posted 03-17-2017 08:18 PM
Best way is to remove door panel and the unplug mirror . Then there are three bolts to remove then you will have the mirror in your hand. At that point you can move the mirror enough to remove the back plate. JU5013105AA drivers Reinstall check electronics before putting door panel back on . |
posted 03-18-2017 05:06 AM
I had to change the glass and backing (all one piece) on my passenger side because part of the plastic backing that attaches to the metal cross that is between the mirror glass and housing/adjusters had broken. The mirror glass with backing will pry/pop off. I adjusted the mirror to give me as much room to see the back and get behind it and them applied a little pressure. Transfer the metal cross, which allows up, down, left, right movement to the backing on the new glass and pop it in. At the time I think it cost me about $65 for the glass mirror. I found no reason to take the whole unit off the car. This message has been edited by Greg and Veta on 03-18-2017 at 05:07 AM |
posted 03-18-2017 09:52 AM
yes please attempt without having to remove door panel. I guess that would be a second option if needed..... robin |
posted 03-18-2017 10:25 AM
quote: Thanks for all the help.....I have some scratches in each mirror that I have tried everything to get them out with no success..I thought I could live with it but they drive me crazy every time I get in my prowler. I will do what Greg said he done and try popping them out. I have ordered a kit from Mopar for each side and hope they will come with a little help....Again, thanks to all...... Dean |
posted 03-18-2017 12:07 PM
You can find the TSB (Technical Service Bulletin) explaining how to install mirror glass here; PR = Prowler http://www.wjjeeps.com/tsb/tsb_wj_2301502.pdf This message has been edited by Tomcal on 03-18-2017 at 12:09 PM |
posted 03-18-2017 06:28 PM
I replaced mine without any problems. |
posted 03-18-2017 09:16 PM
I have never had a problem with the mirrors but I looked around and couldn't find a really good picture of the back side of the mirror or the mirror assemble disassembled. |
ProwlerCar Prowler Junkie From:USA |
posted 03-19-2017 08:38 PM
posted 03-19-2017 09:00 PM
quote: http://prowlercar.com/garage-corner/side-view-mirrors/ [/B][/QUOTE]
Richard Gales Prowler Junkie From:Johnsburg il Usa |
posted 03-21-2017 11:46 AM
Dean sent you a pm on where to get new mirror glass. quote: |
posted 03-21-2017 11:49 AM
Glass mirror replacement. 1-888-482-2279. WWW.HUBCAPSPLUS.COM. Located in Mundelein Illinois |
Patm Prowler Enthusiast From:Casa Rio, SK. Canada |
posted 03-30-2017 10:03 AM
I replaced mine with these. http://shop.muthco.com/plymouth-signal-mirrors |
