General Prowler Discussion Speedometer / Odometer failure (Page 3)
Bottom of Page This topic is 4 pages long: 1 2 3 4 |
Author | Topic: Speedometer / Odometer failure |
posted 10-01-2018 06:25 PM
Thanks for the update and feedback. Glad United Radio treated you right. Some other ideas to check - Check the 11 grounds on the car, start with the ones behind the gates and radio. |
posted 10-02-2018 03:01 PM
Thanks Spoons for the advice!
quote: |
Nick00800 POA Site Supporter Prowler Junkie From:Ridgefield, WA |
posted 10-03-2018 09:21 AM
Any update from sending in the cluster?? |
posted 10-03-2018 10:51 AM
He updated it two days ago. See above. |
posted 10-09-2018 05:11 PM
UPDATE #2: As mentioned, I received my BCM, tested fine according to United Radio. So I took the entire gauge cluster to a well-known tach and speedo shop in my area to diagnose the circuit boards. According to the owner, the boards appear fine but he went ahead and re-floated the boards to assure all the soldered connections were good. Sadly, upon hooking it up, no change, the Gremlin is still winning.. for now. Next step is to purchase a new battery and see if that has any impact. The battery in the car is what came with the car when I bought it about 4 years ago. No dates on the battery to tell me it's age. It's been on a Battery Tender for the last 2.5 - 3 years and volts always register about 13.7 when fully charged. Can't hurt to replace it anyway, right? Maybe a bad cell? Maybe the alternator is causing some voltage issues? Might have it checked out too. If not that, then back to the speedo shop, only this time with the car attached so he can run some diagnostics through the OBD port even though I'm not getting any codes. I will keep everyone posted as I continue my journey, let me know what you think. |
posted 10-09-2018 09:17 PM
Good luck and thanks for posting the updates. Don't you wish everyone did? |
posted 10-09-2018 09:53 PM
Weezy
They were able to determine that the BCM was bad and the alternator was causing the voltage to jump around. Despite me repacing the alternator twice the mechanic told me many parts stores refusrbished alternators don’t do a good job with refurb. The dealer replaced it with OEM alternator and the gages bouncing stopped but many of them did not work. I had United radio fix the BCM and was back to normal. Prior to that I had spent over 40 hrs troubling shooting on my own.
posted 10-10-2018 12:41 PM
Thanks Brian for the information. From all of the posts I've read, I didn't see that you had actually found a remedy to your issue which seemed to be identical to mine, perhaps I missed it. So you said your BCM was bad but sounds like it may have been the alternator causing the gauge issue? United Radio tested my BCM, so don't know if a dealer would test it and obtain different results? Do you suggest I go after the alternator specifically then? I have a message in to my local Chrysler dealership to schedule an appointment, not holding my breath on receiving a response to be honest, but may just drive it in if I don't hear from them Thanks again for your input, it's much appreciated!
quote: |
posted 10-11-2018 08:18 PM
Perform the cluster self-diagnostic test before you do anything else. |
posted 10-12-2018 12:27 AM
Thanks Tom, I did do the self-diagnostic test early on in the process. It would not self test unless the cluster was working which it did intermittently. When it was working, it went through the test just fine. When the cluster stops working, it will not go through the self-test.. frustrating to say the least. As a side note in my adventure of trying to determine what the gremlin is, I had my battery tested today. I found out the battery is over 5 years old and the guy at Interstate Batteries (went there because that's the battery I have in the car), he said "You're battery is going strong". It tested with no issues under full load and did perfectly during two separate lengthy load tests of continuous 600+ cranking amps, stays at 13.7 to 13.8 when charged, no dead cells, and when the water was tested, all cells floated the measurement doo-hicky to the top, etc.. Tomorrow, I have an appointment at a Chrysler dealership 15 miles farther than the one closest to my house as ... no surprise... the one closest to me didn't bother calling me back, they never do. I pray to the Prowler Gods they can diagnose the issue before I go batty.. I'll keep y'all posted |
posted 10-12-2018 05:56 PM
UGH, so the saga continues. Chrysler scanned the BCM and PCM and checked the alternator and said all checks out. When they looked at the circuit boards, their Prowler Tech says he is 100% certain that the culprit is a capacitor on the board because it is bent. I had two separate companies who do nothing but repair clusters who say it's fine, one of which said it makes no difference if it's bent, it's still connected and works properly So, looks like based on everything I have heard on here and researched so far, I have but a couple of possibilities left A. It really is the circuit board and if so, do I send to the Prowler Store or send to the eBay vendors who repair them? Does anyone have experience with either? B. Or, it is a ground issue. If so, I know there are 11 grounds on the car but I don't have a lift, just ramps. Which ground(s) would be mostly likely the culprit? Does anyone know where they all are? I read a post from Jan from years ago but was difficult to distinguish the exact locations from his post. C. ??? Any other possibilities? My frustration level is a 10/10 at the moment, almost don't even care how much the repair cost is at this point, just want this fixed... |
posted 10-13-2018 12:03 AM
When I had trouble with my cluster, the Chrysler dealer said that their scanning equipment said that the cluster was bad. That's as far as their diagnosis could go. Did your dealer's scan say the cluster was good or bad, or was it just a visual check that turned up nothing but bent capacitor wires? Anyway, mine turned out to be a capacitor that had leaked and failed. I found it visually. However, that was a hard fault, not intermittent like yours. I think you should go after the grounds at this point. |
posted 10-13-2018 02:51 PM
Hi Clay, the Chrysler tech only did a visual on the boards, did not test anything. Grounds are next on my list, was just hoping someone might know which ground(s) are most likely to be the culprit. Thanks got the info though! |
posted 10-13-2018 02:57 PM
Brian, hoping you can clarify your post a bit for me. "Behind the gates and radio", not sure where the gates are? And when you say behind the radio, would I need to remove the radio bezel, pull out the radio, etc? Thanks in advance yet again
posted 10-13-2018 03:08 PM
Ground for cluster is located on the right side of center stanchion, near radio. It's a wire that is screwed/bolted to the body in that area. Remove any body paint in that area. Clean area and wire terminal, reinstall. My service manual does not show a picture of this ground location. Besides the ground, you maybe experiencing and intermittent power loss to cluster. I'll check schematics and see if I can find and info for you. There is also another discussion on cluster issues in Technical Section by Chasgriffith that you might like to look at. |
posted 10-13-2018 03:43 PM
Just need to figure what and where right I/P support means and is.
This message has been edited by robin on 10-13-2018 at 03:45 PM |
posted 10-13-2018 04:19 PM
Tomcal, forgive my ignorance, but is this ground under the carpet, behind the radio bezel, or even within the cabin? Robin, I'm guessing the I/P support is what Tomcal mentioned, just have no idea how to get to it I was able to access 3 grounds without a lift, one to the battery and two on passenger side under the car at the center brace. Cleaned and reinstalled, no change I appreciate you guys! If you could clarify how to get to the I/P ground /right of center stanchion near radio, I'll go check that and see what happens. p.s., I have not checked the fuses, still trying to figure out how to access them? Thanks! This message has been edited by Weezy on 10-13-2018 at 04:39 PM |
posted 10-13-2018 04:44 PM
and found this... suggests it is the boards This message has been edited by Weezy on 10-13-2018 at 04:54 PM |
posted 10-13-2018 05:40 PM
On further review of play (schematics), there are two (2) grounds for cluster, on right side(G200) and left side (G201) of stanchion. Stanchion is the metal housing that holds center vents, radio and heat/A/C controls. Also called I/P, instrument panel support. I don't know exact location of ground. Follow main wiring harness under dash, near radio until you find ground wires. G200 is black, G201 is black with light green tracer. They will be attached to metal housing stanchion/IP support. Diagrams are for a 2000. Other years may vary slightly. This message has been edited by Tomcal on 10-13-2018 at 05:46 PM |
posted 10-13-2018 06:48 PM
Thanks Tom! I will see if I can figure out how to get to those grounds and see if it helps once I assure they are clean and connecting properly. Realized I wasn't pulling hard enough on the end cap and gained access to the fuses, they appear fine. Replaced fuse 11 with the spare, no change. Thanks! |
posted 12-05-2018 11:23 AM
UPDATE UPDATE UPDATE UPDATE UPDATE Hallelujah, it appears my gauge issue has been resolved! So about a year or so ago, my gauges started acting weird. All dropping to zero, bouncing up and down, sometimes working fine, sometimes not working at all, digital readout showing weird characters, etc... So here is most of what I did to correct the issue 1. I first had a mobile instrument repair guy come and inspect the circuit boards. Didn't find squat, said the boards were fine. Cost $40 2. Sent my BCM to United Radio - that checked out fine - Cost $40ish for shipping and insurance, no charge for the inspection 3. Checked grounds - cost - just my time 4. Had battery tested - cost - just my time and some gas 5. Had circuit boards fully tested by another company in Tempe, not just inspected. Technician claims the boards are totally fine but thought there may be a solder issue and re-flowed the boards - cost, just my time as he too did not charge for the diagnosis 6. Had Chrysler do a deep scan of BCM, PCM, tested charging system, etc - all tested fine. They claimed it was the capacitor - cost $125 for diagnostics. Chrysler didn't have the ability to provide circuit board repair, so off I go 7. Went back to the company in Tempe with Chrysler's prognosis, he went ape-sh*t, took it personally and wouldn't do anything more 8. Finally decided to contact The Prowler Store and sent my boards there on Oct 19th. Cost $32 for shipping and insurance and $176 for diagnosis. Waited over 30 days before they diagnosed the issue as being a capacitor and needing to clean and re-install resistor above it and 'fix' someone else's 'damage'. Received boards back December 4th. Cost to repair $280 (on top of the $176). Despite the exorbitant cost to repair the boards (still less than buying new boards) and the incredibly long wait just to find out what was wrong, and the anxiety of not even knowing if their repair would work, I am happy (pleased as punch!!) to say that after all of this time, after all of the effort and after way too much spent on this issue, I finally have a working gauge cluster! TPS might be expensive and I know a lot of people rag on them for that, but to be honest, when it comes to the electronics, unless you know someone who knows their sh*t, I'd recommend starting with them to save a lot of pain |
posted 12-05-2018 11:45 AM
Great news. Very glad you found resolution to problem. And thanks for posting a follow-up update. Always good to hear outcome. Prowler on. |
posted 12-05-2018 11:50 AM
Congrats Brian! Glad to hear you are back in business in your Prowler.... Happy Prowling,,ENJOY the RIDE AC |
posted 12-05-2018 02:02 PM
Thanks Tom and Larry, so happy to have this behind me and to have a Prowler that now works like the day it rolled off the line! |
posted 12-05-2018 02:43 PM
Brian when our postal strike is over! I will send you a case of Canadian beer . It's a new Brew called Holy s*@t I think we got it. Knock you on your a$$. This was quite a problem for you . I'm so Glad you finally got this fixed .Nothing worse than Not knowing where to look or what to do next would drive many a men over the edge. What a nice effort by so many that WERE WILLING TO HELP EVEN IF IT WAS A PRAYER. Enjoy the Holidays and rest your mind. |
This topic is 4 pages long: 1 2 3 4 All times are CT (US) Top of Page Previous Page | Return to General Prowler Discussion next newest topic | next oldest topic |
