  Gas
Author Topic:   Gas
galaxie
posted 10-17-2005 11:26 PM     Click Here to See the Profile for galaxie     send a private message to galaxie   Edit/Delete Message   Reply w/Quote   Search for more posts by galaxie
I know that there are many different views on this question about the gas we use in our Kats. Being a new owner, I just got my owners manual. It said to use 91 octane. Where I live we have 87,89,& 93. The manual also said not to use anything over 91 octane. I guess my question is what octane should I use? Would the middle range be o.k?
ALLEY CAT
posted 10-17-2005 11:37 PM     Click Here to See the Profile for ALLEY CAT     send a private message to ALLEY CAT   Edit/Delete Message   Reply w/Quote   Search for more posts by ALLEY CAT
Middle grade is fine,,,,,or use regular unleaded. Computer will adjust to octane.
Call 911 - there is a Prowler in my garage....
Y2K Silver Millennium Edition and '01 Orange Rolex Edition
ed monahan
posted 10-18-2005 01:53 AM     Click Here to See the Profile for ed monahan     send a private message to ed monahan   Edit/Delete Message   Reply w/Quote   Search for more posts by ed monahan
Galaxie, if you are anal, like A/C get half 89 and half 93. I used to always use 93 but saw the error of my ways and cut back to regular.
BeWare
posted 10-18-2005 11:51 AM     Click Here to See the Profile for BeWare     send a private message to BeWare   Edit/Delete Message   Reply w/Quote   Search for more posts by BeWare
I still run Premium in ours. If it was a daily driver I might change that practice. But first I would have to do more research to insure to myself I was not causing the motor any harm. My wife says I am a worry wart.
RPL
posted 10-18-2005 01:04 PM     Click Here to See the Profile for RPL     send a private message to RPL   Edit/Delete Message   Reply w/Quote   Search for more posts by RPL
DCX recommends premium fuel for Prowler. Premium octane varies across the country. In EPA non-compliance areas, they use reformulated fuel which has a 91 octane rating. This is the lowest premium octane rating nationally so that is DCX's recommendation. Other areas of the country offer 92 or 93. Here in Southeast Michigan you can find 92, 93 and 94 octane fuels.
The others are correct. Prowler will run on regular, mid-grade or premium. The ECU will adjust the engine settings to match the fuel that is currently being consumed. The rated horsepower was attained using 91 octane premium fuel.
Using a higher octane rating will not increase the power. It may actually decrease the power as the higher octane fuel burn more slowly. We used different grades of fuel in my Rambler engine while it was on an engine dyno. It made the most power with 92 octane premium. The engine actually dropped in excess of 5 HP with 100 octane unleaded racing gas. The engine builder currently has the car. He will run it on his chassis dyno to reset the carb mixtures. He will also test the power differences between the 94 that is in the car now, 89 and even 87 to see what produces the most power. I'm concerned because this engine is at 11.7 measured compression ratio.
Lone Ranger
posted 10-18-2005 02:52 PM     Click Here to See the Profile for Lone Ranger     send a private message to Lone Ranger   Edit/Delete Message   Reply w/Quote   Search for more posts by Lone Ranger
I always used 91 octane and never had a problem. I don't think the 89 would hurt. JMO
galaxie
posted 10-18-2005 05:11 PM     Click Here to See the Profile for galaxie     send a private message to galaxie   Edit/Delete Message   Reply w/Quote   Search for more posts by galaxie
THANKS TO ALL FOR YOUR INFO. ON WHICH GAS TO USE.
