Author | Topic: Big help please!!!! |
firegabe POA Site Supporter Prowler Junkie From:Ca. |
posted 07-19-2004 07:40 PM
I have exploded the boots of BOTH of my front top A-arms ball joints. was the recall for the top or the bottom? Please Please Please Thanks firegabe |
posted 07-19-2004 07:50 PM
The recall was for the lower ball joints only. |
posted 07-19-2004 09:17 PM
You probably can't get the boots anymore unless someone has them lying around.The upper used a non-sealed balljoint with a separate rubber seal. I'm going to try a balljoint with the same specs as the original except that it's sealed with it's own boot and has no grease fitting.I was told by someone in the know that it will interchange. I'll give them a shot on my new polished front end, but wont get them installed for a few weeks at best. |
posted 07-19-2004 10:35 PM
Firegabe, I heard the ball joints were off a Ford Taurus. I know everyone thinks I am pulling your leg, but I am not. Hopefully someone in the know will chime in. I am not going to divulge a name unless they post. |
posted 07-20-2004 01:23 AM
The ones told to me were off a DC vehicle--doesn't mean the ford ones aren't the same |
posted 07-20-2004 07:55 AM
Very interesting as I have some pinhole leaks in one upper ball joint boot. Dealer overfilled the boot with grease last lube.....(I swear, I'm DONE with dealers..) My temporary fix was to put some silicone over the pinholes. The silicone gets drawn in to the holes and no leaks ever since. I'm getting my one lower ball joint replaced this week as those are sealed, and the boot is torn bad on the lower. My silicone fix didn't work so well on the lower boot, but the upper one is holding nicely. Looks like crap, but holds the grease in... I'd be very interested to see where we can get the boots for the uppers...or even spare upper ball joints. I was lucky to be able to get JUST the lower ball joints as a "recall" kit. |
posted 07-20-2004 11:44 AM
Here's some shots of the top ball joint replacement that I'm going to try. They spec out almost the same with the exception of the small end of the taper being about .030 longer then the stock part. The original one doesn't pull all the way through the knuckle so this shouldn't be a problem. If it looks like it will pull through and not tighten, a washer can make up the space. The other difference is that it uses a larger bolt. It has a nice finish and will make the exposed joint look nicer without needing the plastic cap. The body is the same diameter and the taper is the same. Not sure what material it's made from, but it sure looks shiney.The body of the original was longer to accept the seal. |
posted 07-20-2004 08:03 PM
The lower joints, including the boots are available from Mopar. They were released with the recall. You can order from your local dealers or any of the dealers who have advertised on our board with a discount for POA members. Try the Stratus/Cirrus/Sebring upper joints, which come with a boot. The ones Butchee are showing in the photos should work just fine. |
posted 07-20-2004 08:16 PM
Yup--these are the ones RPL told me should exchange according to his sources. I wasn't going to post a source until they were in and parts exchange verified. |
posted 07-21-2004 02:41 AM
wow you are all so great!!!! Yes please post the phone # so I may get the sealed ones. HUH HUH Shiney is cool thanks! firegabe |
posted 07-13-2005 06:24 PM
the seal pushes up when installed in the arm which is OK and the exposed part will rust so you'll need a cover or some kind of plating to protect.I still don't have them installed with my polished front end. Someday I'll get around to it. |
IM IN XTC unregistered Admin Use |
posted 07-15-2005 12:48 AM
firegabe whats up dude. Wanted to know if you managed to track down those little metal stoppers for the head... remember the guy in Colorado that wanted them Russell.. Yellow and lime green kat Whats up dude when you comming to Denver again |
just jack POA Site Supporter Prowler Junkie From:Oakmont, PA |
posted 07-15-2005 09:23 AM
Most likely happened by overfilling the ball joint... |
