  No More Touch-Up Paint?????
Author Topic:   No More Touch-Up Paint?????
Dead End Don
posted 10-01-2003 12:57 PM     Click Here to See the Profile for Dead End Don     send a private message to Dead End Don   Edit/Delete Message   Reply w/Quote   Search for more posts by Dead End Don
I just found out that Chrysler has stopped making touch-up paint for the Prowler (at least for purple Prowlers).
My local dealer gave me a printout of the dealers nationally who still had any in stock, and it was a VERY short list - 6 had the tubes, and 6 had the spray cans - that's it in the continental U.S. (again, this is according the the local dealer only, and I will happily confirm that they are total idiots in every respect, so if this is bad info, I will go back over there and kick one of their display cars!!)
I am torn between starting a "run" on touch up paint and wanting to let the group know about this potential problem.
MDProwler
posted 10-01-2003 06:34 PM     Click Here to See the Profile for MDProwler     send a private message to MDProwler   Edit/Delete Message   Reply w/Quote   Search for more posts by MDProwler
I just got both brush on and spray touch up from DC for my Orange cat. I need to go back and get the clear spray. I'll check on the purple.
Gary K Orange U Glad?
This message has been edited by MDProwler on 10-01-2003 at 06:38 PM
1buddyc
posted 10-01-2003 06:59 PM     Click Here to See the Profile for 1buddyc     send a private message to 1buddyc   Edit/Delete Message   Reply w/Quote   Search for more posts by 1buddyc
Look for a Paint Supplier in your local area, a Paint Supplier that sells paint to Body Shops. If you cant find one, call your favorite Body Shop and ask them where they get their paint supplies from. Go to the Paint Supplier and give them the Color Code off your Kat and ask them to mix up some touch-up paint for you. They will probably need to mix up some Clear for you also, and the smallest quantity is usually 1/2 pint. Use the Color first and then the Clear after the Color dries. You might get some Touch Up brushes from them at the same time for your touch ups. Should last for a LONG TIME!
If you have a really good Body Shop that you have dealt with before, they might even mix up some touch-up paint for you at no charge. Not a big deal..
Good Luck, Buddy.
Prowler
posted 10-01-2003 07:27 PM     Click Here to See the Profile for Prowler     send a private message to Prowler   Edit/Delete Message   Reply w/Quote   Search for more posts by Prowler
I've been told that any NAPA store can mix any of the colors in a spray can for you.
CJ
posted 10-01-2003 09:09 PM     Click Here to See the Profile for CJ     send a private message to CJ   Edit/Delete Message   Reply w/Quote   Search for more posts by CJ
I'll check with my Mopar contact on this....
BeWare
posted 10-01-2003 10:33 PM     Click Here to See the Profile for BeWare     send a private message to BeWare   Edit/Delete Message   Reply w/Quote   Search for more posts by BeWare
I was also told the touch up was discontinued. It was in fact actually darker than what is on the Purple Kat. You are better off getting the color mixed. However the paint is actually flat. You will also need clear coat unless the mix the clear with the purple pearl color for you. The paint code is PH7.
Dead End Don
posted 10-02-2003 10:30 AM     Click Here to See the Profile for Dead End Don     send a private message to Dead End Don   Edit/Delete Message   Reply w/Quote   Search for more posts by Dead End Don
Wait a minute - you mean that the touch up paint in the tube (1) doesn't match the car color, and (2) I still need to go over it with a separate clear coat??? WTF kind of touch up system is that?!?!?!?!
What about the spray can??? Is that flat also??
I've got two tiny chips that barely show - by the time I'm done layering on the base paint and the clear coat, it'll look worse than it does now with a big raised spot in the paint.
How convenient....
MDProwler
posted 10-02-2003 02:10 PM     Click Here to See the Profile for MDProwler     send a private message to MDProwler   Edit/Delete Message   Reply w/Quote   Search for more posts by MDProwler
If you can get an acrylic enamal touch up paint try this product to make the repair
www.langka.com
This message has been edited by MDProwler on 10-02-2003 at 03:07 PM
Dead End Don
posted 10-02-2003 02:29 PM     Click Here to See the Profile for Dead End Don     send a private message to Dead End Don   Edit/Delete Message   Reply w/Quote   Search for more posts by Dead End Don
MD Prowler, thanks for the info. A couple of questions:
1. Is the factory touch up paint an acrylic enamel???
2. What is this "Langka" product, and has anyone used it with any success?? I mean, is it just a sheet of 420 grit wet n dry sandpaper and instructions on how to fine sand the excess, or is there some "magic" to the product that I can't fathom???
These are really, really tiny chips - maybe the size of a pinhead, but they bug me. I'm very reluctant to start sanding/rubbing away on the center of my hood with "mystery stuff"....
Anybody??????????????????
MDProwler
posted 10-02-2003 03:09 PM     Click Here to See the Profile for MDProwler     send a private message to MDProwler   Edit/Delete Message   Reply w/Quote   Search for more posts by MDProwler
Don,
I'll be the guinea pig. I just ordered a kit. I have been wanting to try it anyhow. Any sandpaper they would give you would be 2000 grit. But this comes with more. I'll post when I get it.
GRROWL
posted 10-02-2003 04:36 PM     Click Here to See the Profile for GRROWL     send a private message to GRROWL   Edit/Delete Message   Reply w/Quote   Search for more posts by GRROWL
No guinea pigs required. A pretty extensive pro-and-con by prowler users is listed at: http://www.prowleronline.com/ubb/Forum9/HTML/001166.html
No sandpaper involved, it's all chemical.
-GRROWL
MDProwler
posted 10-02-2003 05:26 PM     Click Here to See the Profile for MDProwler     send a private message to MDProwler   Edit/Delete Message   Reply w/Quote   Search for more posts by MDProwler
Good info Grrowl. I bought the kit anyway. I have a chip up near the trunk release button I want to fix. This will give me a chance to try it.
CJ
posted 10-02-2003 07:25 PM     Click Here to See the Profile for CJ     send a private message to CJ   Edit/Delete Message   Reply w/Quote   Search for more posts by CJ
UPDATE! I received a message from my contact at Mopar. It states that he did some investigating and there is no more of the Spray Cans and due to low sales, there will not be anymore.
As far as Touch Up paint in the tubes, there will be more available in about a month (maybe less) and I will update you when he lets me know that it is available.
BeWare
posted 10-02-2003 07:56 PM     Click Here to See the Profile for BeWare     send a private message to BeWare   Edit/Delete Message   Reply w/Quote   Search for more posts by BeWare
The paint I am talking about being flat is the actual color mixed by a paint shop. I do not know about the paint in the tube. The paint in the spray can was mixed with clear. I used this to paint die cast models. It came out darket than my Prolwer every time I used it.
WildCat
posted 10-02-2003 08:04 PM     Click Here to See the Profile for WildCat     send a private message to WildCat   Edit/Delete Message   Reply w/Quote   Search for more posts by WildCat
my yellow spray can was flat.....this is due to the fact that the spray can is base coat and then you must spray a clear coat, JUST LIKE THE PAINT ON THE CAR.
Like others have said, GO TO PAINT SUPPLIER AND HAVE IT MIXED
Jim Evans
Prowler Enthusiast
posted 10-03-2003 07:49 AM     Click Here to See the Profile for Jim Evans     send a private message to Jim Evans   Edit/Delete Message   Reply w/Quote   Search for more posts by Jim Evans
The paint on your prowler is a polyurethane two state finish. A flat base coat and the clear, which contains all the properties of filling any sanding scratches, ultraviolet protection, durability and gloss. The base coat just give the color. To do a brush touch up you must use the base color and a clear, here is the recommened way to do it so it is not very noticeable. This is time comsuming it is not just dab the brush in the paint
1) take the 2000 grit sand paper and lightly feather the edges of the chip.
2) clean the area well, if it is down to the bare substrate, apply a primer, the same color as the primer of the car
3) apply the base coat in light applications do not just fill the chip
4) wait for the base to dry the start to apply the clear you will want to use several coat of this. Let it dry between coats, build the clear so it is slightly higher than the oem finish
5) let this dry completely, take out your 2000 grit sand paper and water and lightly wet sand the surface smooth
6) take a fine rubbing compound and buff the area then wax
Hope this helps
Blue Bullet
posted 10-03-2003 04:31 PM     Click Here to See the Profile for Blue Bullet     send a private message to Blue Bullet   Edit/Delete Message   Reply w/Quote   Search for more posts by Blue Bullet
I got my Lanbks yesterday and repaired a chip in my wifes Yukon XL. It does what it says. It disolves the touch-up paint but NOT the factory finish.
One thing I found is that if you don't let the touch up paint dry for at least 4 or 5 hours (I'd reccommend overnight but I couldn't wait to try it to see if it really worked) before rubbing it down as it will go below the unchipped surface rather rapidly. Then you have to aply more touch-up paint and do it again.
But it DOES work and didn't harm the finish on the surrounding area.
Ed
