Thread Closed  Topic Closed
  CD Player Problems
Post New Topic
Author Topic:   CD Player Problems
whealy
posted 05-15-2002 10:05 AM     Click Here to See the Profile for whealy     send a private message to whealy   Edit/Delete Message   Reply w/Quote   Search for more posts by whealy
They just keep piling up …
Anyway, after my first CD player would not eject the cartridge, I received a new player. Now it seems it will play about 2/3 of a son and start skipping. I can scan forward a few songs and after about 30 seconds it start playing again. This has happened while going over rough road and sitting at a stop light. It has happened with older CD’s as well as recently purchased CD’s. I am not currently using any self recorded CD’s.
Anyone else have this issue?
YELLER CAT
posted 05-16-2002 07:00 PM     Click Here to See the Profile for YELLER CAT     send a private message to YELLER CAT   Edit/Delete Message   Reply w/Quote   Search for more posts by YELLER CAT
Did you or the Dealer remove the "transportation screws" from the replacement unit before re-installing it? This is an Alpine built unit... when shipped from the Service Center to the Dealer, the unit has "transportation screws" in place that must be removed. If they have not been removed, the CD chassis cannot "float" on the internal suspension system and "skipping" will occur over bumps as well as other performance concerns may be noticed as well.
Best wishes, Jay
whealy
posted 05-16-2002 09:31 PM     Click Here to See the Profile for whealy     send a private message to whealy   Edit/Delete Message   Reply w/Quote   Search for more posts by whealy
Yeller Cat,
Where is the transportation screw. I understand the concept, I just don’t know where it would be on this unit. I know the unit is easy enough to remove as I did just that in attempting to fix the first one. So if you can point me where so I don’t just take out all the screws …
The path of X's that got me to the promise cat
1988 Honda Accord LXi, 1992 Subaru Legacy GT, 1994 Honda Accord LX, 1994 Mazda 626 ES, 1996 Nissan Maxima SE, 1998 Lexus GS 400, 1999 Porsche Boxster, 2000 Audi A6 2.7T, 2001 Volvo C70
ALLEY CAT
posted 05-16-2002 10:47 PM     Click Here to See the Profile for ALLEY CAT     send a private message to ALLEY CAT   Edit/Delete Message   Reply w/Quote   Search for more posts by ALLEY CAT
My CD player problem:
While adjusting the driver's window up or down, the player seems to stall or slight pause while the switch is engaged. Its OK when I'm changing the passenger's side window from the driver's side control.
Got any ideas??
thanks
Call 911 - there is a Prowler in my garage....
WildBill
posted 05-17-2002 03:00 AM     Click Here to See the Profile for WildBill     send a private message to WildBill   Edit/Delete Message   Reply w/Quote   Search for more posts by WildBill
Could Be an electrical problem... Could be a crossed wire! Ed Monohan is a pro at crossed wires He might be able to help...
Might also be grounded wrong... Something isn't right...
WildBill
ed monahan
posted 05-17-2002 03:04 AM     Click Here to See the Profile for ed monahan     send a private message to ed monahan   Edit/Delete Message   Reply w/Quote   Search for more posts by ed monahan
Since the weather is always nice in Phoenix, the top should always be down and therefore so should the windows be down. Quit playing with the windows. There, I helped.
ALLEY CAT
posted 05-17-2002 07:40 AM     Click Here to See the Profile for ALLEY CAT     send a private message to ALLEY CAT   Edit/Delete Message   Reply w/Quote   Search for more posts by ALLEY CAT
Ed - I'll give your response to the Prowler tech to read.
Thanks Wild Bill for your thoughts, might be the answer.
Post New Topic
