Thread Closed  Topic Closed
  3.5L or 4.7L ??
Post New Topic
Author Topic:   3.5L or 4.7L ??
dpena
Administrating Kat
Visit Dan's Prowler Excitement
posted 08-21-2001 11:56 PM     Click Here to See the Profile for dpena     send a private message to dpena   Edit/Delete Message   Reply w/Quote   Search for more posts by dpena
What do you guys and gals think?? I came across these engines at Woodward and saw the 4.7L engine and thought?
This engine can fit in my Prowler ??
Here are both engines side by side!!
butchcee
posted 08-22-2001 02:08 AM     Click Here to See the Profile for butchcee     send a private message to butchcee   Edit/Delete Message   Reply w/Quote   Search for more posts by butchcee
Hi Dan, looks like the real issue is front to rear length and weight. You thinkin DC is gonna step~up? That would sell some cars I bet.
Yellow is DCOOLEST
CWatsonJr
posted 08-22-2001 10:33 AM     Click Here to See the Profile for CWatsonJr     send a private message to CWatsonJr   Edit/Delete Message   Reply w/Quote   Search for more posts by CWatsonJr
Here is where I show that I know squat about engines...
Why would you put a V-8 in there that uses more gasoline than the V-6 we have now AND it produces LESS horsepower? Or would the HP go up being put in such a light car?
Just wondering.
Cliff Watson
cnote6
posted 08-22-2001 10:36 AM     Click Here to See the Profile for cnote6     send a private message to cnote6   Edit/Delete Message   Reply w/Quote   Search for more posts by cnote6
Thanks Dan.
TGF Spoiler, Hardtop,Front Grill, Doorpanels
Real Rod Exhaust & Mopar Exhaust
2000 Black Bumpers & Chrome Shimmers
Carlini Trans Cover,Chrome headrest, Brake Lines, Bumper Cover Kit
Chromed Front & Rear of Kat & Front End Protectors
Chrome 2000 Shifter, Purple Neon underneath
Dunlop SP 9000's & 6 cool CD's in the changer
butchcee
posted 08-22-2001 12:23 PM     Click Here to See the Profile for butchcee     send a private message to butchcee   Edit/Delete Message   Reply w/Quote   Search for more posts by butchcee
Cliff, while the HP is important, so is the torque.Think of HP as the max amount of pulling power you have and torque as how fast you can get up to that pulling power. A diesel vehicle has lower HP then gas engines of the same cubic inch displacement(Not you Gary ), but GOBS of torque to pull heavier loads. These figures are adjusted by rod length, bore~stroke differental, compression ratio, and cam profile to name a few. Also, torquier engines are easier to drive with more power being delivered at lower RPM's. The larger displacement engine will turn lower RPM's and might bring the fuel usage close to the 6. The big thing is the sound.
Like Larry says! "shudda had a V8". Hope this helps and I'm sure I left out some stuff.
Yellow is DCOOLEST
dpena
Administrating Kat
posted 08-22-2001 12:29 PM     Click Here to See the Profile for dpena     send a private message to dpena   Edit/Delete Message   Reply w/Quote   Search for more posts by dpena
Cliff,
Torque is what moves mass and horsepower is what gives you high speed.
The horsepower issue would be quickly resolved by taking out some of the air flow restrictions that are always present on a stock engine. A V8 would allow our Prowler to continue living.
Al,
You are correct. I did take picture of the side by side comparison. They are longer in size. The 4.7L is about 6 inches longer
Later....
dpena
Administrating Kat
posted 08-22-2001 01:52 PM     Click Here to See the Profile for dpena     send a private message to dpena   Edit/Delete Message   Reply w/Quote   Search for more posts by dpena
fortknox82
posted 08-22-2001 02:07 PM     Click Here to See the Profile for fortknox82     send a private message to fortknox82   Edit/Delete Message   Reply w/Quote   Search for more posts by fortknox82
Well since width does not look like an issue and its only length then why dont one of you rich guys cut away the firewall a little bit and make it work. Id do it since it doesnt look too bad but then again i dont have the time or resources to do a job like that. I mean how much work could it be to relocate the items under the dash to make it work. And then again, there are accessories on a V8 that could be moved around. and you dont need the fan since you would have electric fans. i think it could happen with a little know how and money.
Jason - 2001 Orange Prowler - Youngest Driving Prowler Owner
Amsoil Engine and Tranny Fluid
Magic Touch Designs Intake
Carlini Trans Cooler Cover
Purple Neon Lights Underneath
TGF Ground Effects
Mopar Performance Exhaust
Custom Shade Shift Magenta to Gold Flames
Prowler Pro Gears soon...
CWatsonJr
posted 08-22-2001 02:31 PM     Click Here to See the Profile for CWatsonJr     send a private message to CWatsonJr   Edit/Delete Message   Reply w/Quote   Search for more posts by CWatsonJr
Thanks for the lesson guys!! Dan - is that the same 4.7 they are putting in the Durangos and Dakotas?
I don't think length is really that much of an issue - may have to modify the fan to fit the more narrow area of the prowler nose but think about how much room you have up there where the battery sits. I don't think you would have to cut the firewall - maybe change the way the front end is braced though.
Dan - was it a V8 they had in that prowler at Woodward?
Cliff Watson
dpena
Administrating Kat
posted 08-22-2001 08:52 PM     Click Here to See the Profile for dpena     send a private message to dpena   Edit/Delete Message   Reply w/Quote   Search for more posts by dpena
Cliff,
I believe these are the engines going into the Durangos. As far as what type of engine that DC prowler driven by Jerry had, is unknown to me. He would keep closing the lid as soon as he noticed someone was getting close to figuring it out.
After looking in my Prowler, I realized I have already pushed my radiator forward about 4 inches. I had to do this to fit my new larger radiator. I had the front brace redone and stretched.
If I was to go back to my stock radiator and take off the belt fan on that 4.7L engine. I just might be able to fit that thing.
Later...
CJ
posted 08-22-2001 09:04 PM     Click Here to See the Profile for CJ     send a private message to CJ   Edit/Delete Message   Reply w/Quote   Search for more posts by CJ
Yes, guys, this is the same engine that is in the Durangos, Dakotas, Ram and Grand Cherokee. It is also the same engine that is in the "Howler". Let's see.....does it fit? You be the judge!
CJ - The One and Only - 1999 Black
Mopar Exhaust System
Splash Guards
Matching Prowler Trailer
PProwler Vanity Plate
Classic/Beautiful - I'm referring to the Cat of course!
CWatsonJr
posted 08-22-2001 09:48 PM     Click Here to See the Profile for CWatsonJr     send a private message to CWatsonJr   Edit/Delete Message   Reply w/Quote   Search for more posts by CWatsonJr
Dan - I think CJ answered your question AND THEN SOME (if you get my drift) shhh.
Cliff Watson
Post New Topic
