Author | Topic: Bumper removal |
NVRMND POA Site Supporter Prowler Junkie From:Houston, Texas usa |
posted 07-27-2001 11:39 AM
Does anyone have any suggestions on removing the bumpers. I have looked it over for a month now, and I guess I am going to give it a shot. Mind you I have not wrenched in 5 years. I would like to do it as easily as possible and your comments would be helpful. I am sending off for the Tom Mills package. Keep in mind last night it took me an hour to put on the front mud flaps. I did it with out jacking the car up and with out removeing the wheels. My hands feel like they were run over by a truck. Thanks in advance. |
posted 07-27-2001 11:48 AM
Click here ------------------ |
posted 07-27-2001 11:50 AM
I hope you put locktite on the t-bolts for the mudflaps they will loosen up in time. ------------------ |
posted 07-27-2001 11:52 AM
Ed.....have taken off several sets of these recently, this was the quickest by far.....all I used were a 13mm socket and a 13mm box end...the trick I have found is getting the right ratchet...needs to be short and low profile (flat) ...the only place I have found these ratchets is Sears...any thing else is a waste of time....I learned the hard way....use the socket on the bolt and the box on the nut.....work against each other(quicker)....do the top inside bolt first then the outside(most difficult)...I put a box under the bumper so when I loosen the last bolts the bumper has something to rest on....one plug per side to disconnect....thats it....easy with the right tools, nearly impossible otherwise....good luck Y2K YELO X 3 |
posted 07-27-2001 01:54 PM
Chrome, Find a nice big tree, wrap a couple of towls around your bumper (so not to scratch the bumper) Pull up to the tree with one foot on the Brake and on foot on the gas, Then punch it!!! you will hear a slight crack then press the brake. Real easy to do. Gary does not kow what he is talikg about. ------------------ |
posted 07-27-2001 02:47 PM
Bumper removal is easy, but it is frustrating and time consuming. The bolts will only move one or two clicks at a time. I used a ratchet type box end wrench and the ratchet on the other end. Working against each other gives you 3 or clicks at time. I also found that taking the grille out makes it easier to reach. ------------------ |
posted 07-27-2001 03:03 PM
I almost did a bumper removal on the Beetle a minute ago, I left the car in neutral and rolled into the street, wow, I be stupid. |
posted 07-27-2001 04:16 PM
Gary, WOW you noticed!!!IBS ------------------ |
posted 07-28-2001 12:48 PM
Ok, I think I am going to take chris's advise. I can get my hands on three of them.But the forth(upper closest to the body panel), is impossible to reach! I am going to look for a big tree. BTW, I have by grill off and it helps NOT! |
posted 07-28-2001 02:06 PM
I took out the headlight assemblys and reached all the bolts that way ------------------ |
posted 07-28-2001 02:25 PM
Chrome,LOL!! ------------------ |
posted 07-28-2001 07:29 PM
I still can not reach that top bolt! I am using a 1/4 drive with a 13 mm socket. What is the deal!!!!!!!!!!!!!!!!!!1 |
posted 07-29-2001 01:38 AM
Chrome - read above again, Sears brand, smallest, flatest, shortest 1/4" ratchet they make. Anything else is a waste of time. Take your time, you have no choice here, and swear alot. Makes things go much faster! I wouldn't take the headlights out, unless you are good with a wrench. Spacers falling under car, light adjustment reinstalling, etc - could be more problems than the extra time spent doing it as above stated. JMO Good Luck |
posted 07-29-2001 07:46 AM
Chrome, you do realize that the bolts are inside a triangle similar to the one that shows on the front of the bumpers. You have to go under the lower edge to reach the bolt and then it will only move one or two "clicks" on the ratchet. When these guys are talking about using box end ratchets on both the nut and the bolt, I am not following that. Mine were attached with a strip of metal so that you could not turn the nut, PERIOD. I guess that held them in place while they used an air wrench to attach them. It is not hard to do, other than it is a S-L-O-W process. |
posted 07-29-2001 09:25 AM
the old posting by Y2K YELO X 3 was me...I have taken off several sets with out removing any body panels...yes, it is tedious...the last set I removed took a total of 18 minutes for the entire ordeal...it all comes down to having the right ratchet, that is the total key to success on this job.....good luck and make that trip to Sears...nothing else will do the job that I have found yet... ------------------ |
posted 07-29-2001 12:56 PM
My ratchet is maybe 5 inches long. I guess you guys mean shorter than that cause, it just aint happening. I am headed to sears again to see if they have something smaller. I am also gonna try to get a 13mm box end ratchet. More progress to be reported should I have any! |
posted 07-29-2001 02:26 PM
HOLY SH@T ITS OFF, THE RIGHT FRIGGIN SIDE IS OFF!!!!!!!!!!!!! MY WRIST WILL NEVER SERVE ITS INTENDED PURPOSE AGAIN, BUT IT IS OFF. 1 MONTH, 1 WEEK, 74 HOURS AND 31 MINUTES! IT IS OFF. I WILL REPORT BACK ON THE OTHER SIDE WITH COMPLETION TIME!!!!! |
catterumpus Prowler Junkie From:rapid city, SD USA |
posted 07-29-2001 03:24 PM
Congrats! That's about par for the course, counting all the profanity. Like they said, with the right tool... But that fourth one in the little triangular space will test you. For anyone about to have this experience, have faith, it can be done. ------------------ |
posted 07-29-2001 03:31 PM
WOW, LEFT SIDE OFF AND GRILL BACK ON IT 24 MINUTES. IT CAN BE DONE, EVEN BY A MORON! NOW WHO HAS THE BEST KIT, I AM THINKING OF TOM MILLS. I HAVE SEEN SOME THAT LOOK LIKE THE REAL RODS BUT WITH TURN SIGNAL BUILT IN. ANY SUGGESTIONS. WOW MY WRIST HURTS!! |
posted 07-29-2001 04:30 PM
I have Tom's kit in my car. The color match was perfect and went on really easy. ------------------ |
posted 07-29-2001 07:58 PM
Hey Chrome, this post may be too late to help you but I found the easy way too pull the bumpers is to first remove the headlight assemblies. With those out of the way, there's an access hole that makes getting at the 2 outboard bolts easy-piece o' cake, no special tools. Just pay attention to any spacers that may be under the headlight assy. Some cars have 'em, some don't. |
posted 08-11-2001 02:49 PM
Chrome, I went to two Sears stores in Cincinnati today and they do not have a shorter rachet than your 5+ inch unit. They looked in their regular and commericail catalog and no shorter 1/4" rachet is listed. What is going on guys? I have a Sears 1/4" rachet and is is exactly 51/2" and 1/2" thick body. Maybe this shorter rachet is discontinued? Rich ------------------ |
posted 08-11-2001 03:52 PM
Richard, It is a 3/8th drive, short handle. I did not realize you did not know that, sorry. If you can't find one give me a call and I will lend you one. My son has a swivel necked 3/8 but that was actually a hinderance. |
posted 08-12-2001 12:22 AM
LOL, ed ------------------ |
