Thread Closed  Topic Closed
  MudFlaps- Mud flaps??
Post New Topic
Author Topic:   MudFlaps- Mud flaps??
NVRMND
posted 05-18-2001 08:18 PM     Click Here to See the Profile for NVRMND     send a private message to NVRMND   Edit/Delete Message   Reply w/Quote   Search for more posts by NVRMND
WHo is the vendor of choice for mudflaps? Many thanks!
tangled up in BLUE
posted 05-18-2001 08:49 PM     Click Here to See the Profile for tangled up in BLUE     send a private message to tangled up in BLUE   Edit/Delete Message   Reply w/Quote   Search for more posts by tangled up in BLUE
The ONLY vendor I am aware of is your local Chrysler dealer....usually have them in a day or two...get front and rears....easy to install...a MUST for the cars if you intend to drive it at all...
X-Black 99
X-Silver Bullet
X-Black 2000
X-Y2K YELO X 4
CJ
posted 05-18-2001 10:20 PM     Click Here to See the Profile for CJ     send a private message to CJ   Edit/Delete Message   Reply w/Quote   Search for more posts by CJ
Definitely MOPAR...........and yes, they are necessary! Cheap insurance............
CJ - 1999 Black
Matching Prowler Trailer
Stock / Classic / Beautiful
PROWLEN
posted 05-18-2001 11:44 PM     Click Here to See the Profile for PROWLEN     send a private message to PROWLEN   Edit/Delete Message   Reply w/Quote   Search for more posts by PROWLEN
Speaking of mud flaps...
Mine are tight but the front ones seem to rattle.
Does anyone else have this problem or has noticed this?
Thump your fender on top and see if they rattle.
The flap extending from the fender seems to need some insulation at that point.
Does anyone have an easy fix?
Thanks...
Prowl-On...
PROWLEN.... John (-:
Alex
posted 05-19-2001 09:20 AM     Click Here to See the Profile for Alex     send a private message to Alex   Edit/Delete Message   Reply w/Quote   Search for more posts by Alex
Order them from the dealer!!! They should have them in 2-3 days. All 4 cost around $65.00 and are very easy to install. In my opinion a MUST if you drive your KAT.
Alex
2001 Orange Kat
Mike Krehel
The World's Quickest Prowler (11.65 sec) and Administrating Kat
posted 05-19-2001 10:07 AM     Click Here to See the Profile for Mike Krehel     send a private message to Mike Krehel   Edit/Delete Message   Reply w/Quote   Search for more posts by Mike Krehel
Chrome,
Mud flaps are a must. Here are the part numbers:
-Mud flap front #82203235
-Mud flap rear #82203236
Prowlen,
Check to make sure all the nuts are snugged up. There are three nuts per front flap. The nuts have a tendency to work themselves loose and the bolt head behind the flap will rattle. Be sure to put Locktite on the nuts to keep them from coming loose.
Mike Krehel
ProwlerOnline.com Click and see me go!
SPCL-T
posted 05-19-2001 10:18 AM     Click Here to See the Profile for SPCL-T     send a private message to SPCL-T   Edit/Delete Message   Reply w/Quote   Search for more posts by SPCL-T
Mike is totally correct. Mine came loose, and I actually lost 2 out 3 nuts on one side. Loctite & elbow grease to ensure they are secure.
After you install them, be careful around speed bumps and such. The front ones are so low to the ground, they will drag. I haven't seen any damage other than they just become loose over time. Drive at a angle as you go over speed bumps, it will lesson the grad and minimize potential dragging of the mud flaps.
If the flaps become loose, be careful. When they vibrate or rattle, the flap is rubbing on the underside of the fender, which over time, will rub off paint. FYI
SPCL-T
NVRMND
posted 05-19-2001 11:40 AM     Click Here to See the Profile for NVRMND     send a private message to NVRMND   Edit/Delete Message   Reply w/Quote   Search for more posts by NVRMND
You guys rock!, Thanks, I will call dealer Monday and order them.
Todd Cameron
unregistered
posted 05-19-2001 04:36 PM           send a private message to NVRMND   Edit/Delete Message   Reply w/Quote   Search for more posts by Todd Cameron
Actually, even with Lock Tite they come loose if yours rub on speed bumps which the ones here ALWAYS do. What you want to do to prevent looseness and "vibration", is to install a flat washer and then a lock washer and THEN the factory nuts.
2000 Black, 2001 Black Tie, 2001 Orange
FatManInTheBathTub
posted 05-20-2001 08:16 AM     Click Here to See the Profile for FatManInTheBathTub     send a private message to FatManInTheBathTub   Edit/Delete Message   Reply w/Quote   Search for more posts by FatManInTheBathTub
Hey now, I use ss locknuts as I lost a few nuts too. Also, the SPC control for the f. fenders must have a large tolerance. I noticed my left flap would scrub when I turned into my driveway everytime. I took out the tape measure, found that the fenders hang down a half inch different. Trimed the left so now the flaps are even and no more scrub............
Daryl
posted 05-20-2001 11:25 AM     Click Here to See the Profile for Daryl     send a private message to Daryl   Edit/Delete Message   Reply w/Quote   Search for more posts by Daryl
My mud flaps also raddled, and drove me nuts! My tech put some thin pieces of foam material, with sticky tape on both sides of it, between the mud flap and where it attaches to the fender. It's been about 2 years since then and I still don't have any rattles.
Daryl
posted 05-20-2001 11:27 AM     Click Here to See the Profile for Daryl     send a private message to Daryl   Edit/Delete Message   Reply w/Quote   Search for more posts by Daryl
<raddled>??! Don't know where my brain is today, can't even spell rattled!
Post New Topic
