General Prowler Discussion What Mods will you do in the next 6 months? (Page 1)
Author | Topic: What Mods will you do in the next 6 months? |
Alex POA Site Supporter Prowler Junkie From:Westminster, CO USA |
posted 05-09-2001 05:09 PM
What modifications do you plan to do in the next 6 months, and if you want what mods do you already have completed?
Installed Mods ------------------ This message has been edited by Alex on 05-09-2001 at 05:13 PM |
A1A ROD Prowler Newbie Personal ScrapBook From:Atlantic Beach FL |
posted 05-09-2001 05:48 PM
Modifications already done: Mopar Performance Exhaust Modifications underway as we speak. M&L Automotive polished stainless steel grille Modifications under consideration: Prowler Gears ------------------ |
posted 05-09-2001 05:54 PM
First rebuild motor{hehehehe) Add Nitrous Ceramic Pads Put on my Carlini Rear Wheel Spacers Custom two tone paint by Nyle Wing And maybe lower the Car an inch |
cwatsonjr unregistered Personal ScrapBook Admin Use |
posted 05-09-2001 06:23 PM
Modifications Done: Mud Flaps (front/rear) Considering: Paxton Supercharger
This message has been edited by cwatsonjr on 05-11-2001 at 08:39 AM |
posted 05-09-2001 08:13 PM
Install a Chysler 413 cu. in. hemi,, almost done,,,, ------------------ |
posted 05-09-2001 08:55 PM
413 hemi? ------------------ |
posted 05-09-2001 09:00 PM
yup |
NVRMND POA Site Supporter Prowler Junkie From:Houston, Texas usa |
posted 05-09-2001 09:07 PM
Drive it. |
REBELBOB POA Site Supporter Prowler Junkie From:Pamplin, VA |
posted 05-09-2001 09:17 PM
how difficult of a fit ? |
posted 05-09-2001 09:27 PM
I'm sorry Rebel,, I was just joking.... would be nice tho.. ------------------ |
viper93 Prowler Enthusiast From:York SC US |
posted 05-10-2001 05:58 AM
I am going to change out my rear bumper for chrome , I have aleady changed out the front. |
posted 05-10-2001 09:19 AM
Hey now, I am trying to modify my fuel pump regulator. I will first try to find a new spring for it. If not, I will try a spacer under the original spring. Need to find out what device is controlling the rev limiter and what to do to trick it. Then I drop in the 10 sec motor. See what it will do then on to the 9's.................baby steps....... |
posted 05-10-2001 09:39 AM
Jerry, why not replace your present regulator and pump, or run a parallel system to kick in when the pressure drops? So JD, what's a 413 hemi? I know of the max wedge at that displacement. Is that the size of the new motor DC has? ------------------ |
posted 05-10-2001 10:11 AM
Hey now Al, I have done some checking into different systems. The problem is the prowler is a deadhead system. All the manufactures I have spoken to say I would need new fuel rails. In the prowler service manule, it says that the prowlers fuel pump can produce a max of 130 psi deadhead pressure. I only need maybe 10 psi. more than what I am getting now. If you know a supplier with a system that would work with the present system, let me know and I will find out. I'm gonna need this fix to get in the mid to low 11's............ |
posted 05-10-2001 10:32 AM
See if you can get Mike to give it up (fat chance) I remember reading about a tank sump and aux pump somewhere-maybe Gary? Talk nice now Jerry!!! ------------------ |
posted 05-10-2001 10:43 AM
Al, If I remember correctly, 413 is the final cu. in. of a bored and stroked stock motor back in 69. I could be wrong, but a friend of mine had it in a 55 Chevy. It was one of the quickest cars I've rode in. Course, the front seats never got bolted down (before he wrecked it), so that added to the feel when he would pop wheelies.
posted 05-10-2001 01:29 PM
Hey now, I was asking for info from others that know from experience. Anyone that has unlimited mola can just pay. Where I am now, only experience can solve. This ain't no boat, so Gary "The Engine Blower" can't help, I guess he put too much pitch on that prop. He's too busy taking bets on how long it will take a prowler tech to swap out his blown motor. He can use that blown motor for a boat anchor. I guess he is the first to blow a prowler motor, so what does he know??? Anyway, I was just asking. Mike hasn't responded to any of my post since I clipped his nads and took'em back to FL. with me. So Butchee.........come clean with the info! |
posted 05-10-2001 02:08 PM
Jerry, I haven't done any work on my fuel pump yet. I had the Auto Meter resettable fuel pressure meter and the pressure dropped down to nearly 30 psi with a 50 shot that day at the track. The existing pump can probably supply a greater pressure with a regulator spring change and you will have a more pressure until you need more fuel for the supercharger/nitrous, then I don't think that the existing pump will supply enough volume of fuel. I think the best approach is to replace the fuel pump with a higher delivery unit. It looks like you're on the right track with your new motor! Will Bubba be taking video at your next track outing? I saw some of the pictures that Jerry Heasley took at the track and your MT's looked pretty wicked wrinkling up on your launches! BTW, my nads are just fine thank you! |
posted 05-10-2001 02:10 PM
Chrome under the hood, TGF side panels (when they are ready) And the list I have done, Just look at the purple letters.Thanks Gary. ------------------ |
posted 05-10-2001 02:35 PM
Hey now Mike, hows they haggen....So when you gonna head back to the track??? I just got a call that I will get my car back tomarrow. If I get the fuel thing fixed, it looks like next Fri. I'll be back for that 11 sec run. The new motor is comming along, it will be a 10 sec for sure if the tranny holds out. I got Wiseco making me some lightweight pistons. They were inpressed with how well the prowlers stock pistons are constructed. The only bad thing they feel the top ring is too close to the top, the ring gap is a little excessive for racing and the pin could use a cross drilled oil holes but overall, a great stock piston. I'm also gonna get new rods with a smaller pin hole so to loose some weight there too. I still need to find someone to do my heads, you know, larger exhaust valves. Champion Racing Heads are made here in Palm Coast but they are way over booked. I'm looken for another source as I cant wait 2 months to get this motor done........... |
posted 05-10-2001 03:44 PM
Hey now Jerry. Here's your MT tire action! |
posted 05-11-2001 12:41 AM
Edited, as to not offend. Alex ------------------ This message has been edited by Alex on 05-11-2001 at 08:57 AM |
posted 05-11-2001 01:51 AM
Alex, Sometimes topics get side tracked and sometimes you can learn more from the path that they take. Fuel pump delivery problems... Bored and stroked? These are some of the mods that are currently being done to make our Prowlers go faster! Getting back to your question, I plan on putting the Mopar exhaust on my Mulholland tomorrow. My current mods are:
posted 05-11-2001 04:25 PM
Jerry, Why you going with the smaller pins? Why not tool steel tapered light guys? This way you'll still have the same piston load area. New pistons-forged or cast?. If forged, they'll probably be heavier-top ring up too far will break under detonation. You're gonna rebalance all-right.? This guy Matt at Finishline claims he has ported Cat heads with a 30 HP rear wheel gain. I'll see soon. He claims he can supply larger valves, but I'm not going that way. He's almost caught up and I expect to give him my car next week-1 1/2 months late! ------------------ |
posted 05-11-2001 05:32 PM
It's summertime Al, cruisin time. How long will your car be under the knife?? ------------------ |
