General Prowler Discussion How do you change headlight bulbs?
Author | Topic: How do you change headlight bulbs? |
posted 03-26-2001 10:27 AM
Hi Does anyone know how to get to the headligh bulbs. I want to replace them with ultra white Xenon. I have them for the PT Cruiser and love them. What a difference. Also does anyone know the stock bulb wattage? Thanks |
posted 03-26-2001 10:58 AM
I have PIAA, 65 watts, want a difference, you need to take the top cap off of the light assembly. Not easy, let your local tech do it and remember don't ever touch the glass on the bulbs, they will burn out. Good Luck |
PROWLEN Prowler Junkie From:Wa. USA |
posted 03-27-2001 11:12 PM
I upgraded my headlamps also to some APC SUPER WHITES XENON PLASMA 100 watt #9005, or PIAA equivalents and kept having one go out. It wasn't that the bulb was burning out but that the heat had melted the socket connection and wiring harness a bit. I changed back to stock lamps before any serious damage had occured. I haven't had any problems since. Also please note that there are eight screws to the housing lid. Three of them are different. They are the same length but look like self tapping verse pointed sheet metal screws. They go in the three outboard tabs spaced around the outside of the housing. I think that the housing design allows the heat to build up, and the high performance bulbs have the potential to cause serious damage. You might inspect your wiring harness under the cover if you have had high output lamps for awhile. I had mine in for about 4,000 miles before the problem developed. I hope this helps someone and saves possible damage.
------------------ PROWLEN.... John (-: This message has been edited by PROWLEN on 04-21-2001 at 03:12 AM |
posted 03-28-2001 07:54 AM
John - thanks for the info. MADMAX Swider may want to exchange those bulbs he won at TMS. This message has been edited by ALLEY CAT on 03-28-2001 at 07:55 AM |
posted 04-16-2001 11:24 PM
hmmm, what about those neon blue type kits that are avaliable... any info on these? ------------------ |
posted 04-17-2001 03:11 AM
I am getting some Xenon HID Blues in this thursday. I will let you know how they look. Sasy ------------------ |
