General Prowler Discussion There was a service bulletin on the 99 trannys, who had it done?
Author | Topic: There was a service bulletin on the 99 trannys, who had it done? |
posted 12-08-2000 12:09 PM
Why I ask, is the Leopard Cat is a little soft in the shift compartment, those that have done it please explain the before and after results. thanks ------------------ |
posted 12-08-2000 01:04 PM
Gary, I had it done to mine and it was a big difference. Especially on 3rd gear. Before the TCM upgrade when I would be at around 90 miles an hour and then floored it to acheive 120 miles per hour. My cat went out of 4th gear lock up to 4th gear then downshift to 3rd gear and speed began to increase with alot of hesitation. It almost seemed like the tranny was shifting from 3rd gear to 3rd gear lockup. It could not make up it's mind whether to go into 3rd gear lock up or not. After the upgrade, 3rd gear will stay flat and not oscillate all the way up to 120. Definitely do it! Dealer upgrades with this diag prob- Here is their download station-
posted 12-08-2000 01:33 PM
YOU ARE THE ANSWER MAN. Thanks ------------------ |
posted 12-08-2000 01:49 PM
Thanks from me too Dan. Your descripton is exactly whats happening to my 2K, But I didn't notice it till after the gear change! Mine bangs 3rd fine but then kinda sllliiiiddddes into lockup! If we could defeat lockup with a switch, acceleration would be better. ------------------ |
posted 12-08-2000 02:11 PM
I might be wrong but I think this upgrade is only for the 99's. ------------------ This message has been edited by Gary C on 12-08-2000 at 02:16 PM |
posted 12-08-2000 02:34 PM
Anyone have any idea's then? Neal, where are you? ------------------ |
posted 12-08-2000 02:36 PM
OK, it is for the 99 only, my 2000 does the same thing you are talking about Al. ------------------ |
posted 12-08-2000 02:57 PM
Are you going to try and fix it or just deal with it G.? ------------------ |
posted 12-08-2000 03:06 PM
The 2000 is the way that it is. The 1999 is fixable. ------------------ |
posted 12-08-2000 05:50 PM
Now that doesn't make any sense! ------------------ |
Nyle Wing Prowler Junkie Personal ScrapBook From:USA. |
posted 12-08-2000 06:47 PM
Took mine to the dealer and there was no update available for it. But mine shifts fine. ------------------ |
posted 12-08-2000 07:19 PM
It depends on a early or late model. ------------------ |
posted 12-14-2000 08:01 PM
I should not have done it, now it wonders in 3rd and it didn't do it before. |
posted 12-14-2000 09:10 PM
You had the tranny updated Gary? Thats too bad you got those results. ------------------ This message has been edited by butchcee on 12-14-2000 at 09:13 PM |
Y2KRedProwler Prowler Junkie From:Los Angeles Area, CA,USA |
posted 12-14-2000 10:28 PM
Mine is a very early 2000 model (I think it was made the first day the 2000 model went into production). I asked the tech a few weeks ago when I was there to check about an update on my 2000, he said there is one, but as long as I wasn't having any trouble DON"T DO IT! Then again....I'm not driving between 90-120! Got close last week following GARY C! |
posted 12-15-2000 08:35 AM
Dan, do you have any numbers for this "fix" or upgrade to the tranny? I've check the tech bulletins and do not seem to find what you mentioned. Thanks. ------------------ |
posted 12-15-2000 09:14 AM
Y2KRED-Did your tech give the reason for not performing the update? ------------------ |
posted 12-15-2000 10:53 AM
Tech said as long as I was comfortable with present pereformance don't fool with it. He said he would upgrade if I wanted him to. Sorta like, "if it isn't broken, don't fool with it!" |
Todd Bertrang unregistered Admin Use |
posted 12-15-2000 02:13 PM
yea, I hit 95 for the 1st time trying to catch up to you racer's! ------------------ |
